distrib fit
March 30 2007 at 7:35 AM
  (Login 00llama)
from IP address 69.106.78.9
Response to Re: MEL CAMSHAFT INTERCHANGEABILTY
Should be no problems. I had no problem with mine. Fit perfectly, no problems. I ran a 505C. Suggest you upgrade distrib to electronic. Petronix, Mallory and Accel all have quick drop in kits for under 100 dollars that will avoid the aftermarket "Will it fit?" drama. TJR
  1. Re: distrib fit - brian on Mar 31, 7:56 AM
    1. dist gear - treinarts on Apr 2, 4:10 PM
      1. Cam Bearing Interchangability - Mike G. on Apr 28, 7:15 PM
        1. Previous Post Source - KULTULZ on May 7, 5:16 AM
          1. KULTULZ, I posted block bore ID for cam bearing - gary534 on May 7, 6:06 AM
            1. CORRECT... - KULTULZ on May 8, 6:25 AM
