Previous Post Source
May 7 2007 at 5:16 AM
from IP address 69.140.42.35
Response to Cam Bearing Interchangability
Mike G.
(Login Homespun91)
April 28 2007, 7:15 PM
"I've been following this with a great deal of interest. I noticed that in another post, Brian Perrenot points out from personal experience that the bearings will not interchange; & looking at the block bore IDs as posted, he's right.
Since the late bearings have a smaller OD,"
Can you point me to this previous post (the layout and operation of this forum sucks)?
While the actual block cam bore size(s) is not given in the later shop manual, they have to be the same. The individual bearings would have increased I.D. but the actual bearing material should be the same guage thickness, shouldn't they?
  1. KULTULZ, I posted block bore ID for cam bearing - gary534 on May 7, 6:06 AM
    1. CORRECT... - KULTULZ on May 8, 6:25 AM
