Cam Bearing Interchangability
April 28 2007 at 7:15 PM
Mike G.  (Login Homespun91)
from IP address 70.106.221.86
Response to dist gear
I've been following this with a great deal of interest. I noticed that in another post, Brian Perrenot points out from personal experience that the bearings will not interchange; & looking at the block bore IDs as posted, he's right.
Since the late bearings have a smaller OD, I suppose steel sleeve rings could be made & installed. Failing that, it appears that either A) a custom billet cam would have to be made; B) an earlier '58-'60 Isky/etc. blank, or roller, would have to be located; or C) a stock early cam would have to be reground to the desired profiles. Hmmm.
I don't suppose that the Isky catalog had any more specific details??
  1. Previous Post Source - KULTULZ on May 7, 5:16 AM
    1. KULTULZ, I posted block bore ID for cam bearing - gary534 on May 7, 6:06 AM
      1. CORRECT... - KULTULZ on May 8, 6:25 AM
