dist gear
April 2 2007 at 4:10 PM
  (Login 00llama)
from IP address 69.106.78.9
Response to Re: distrib fit
58-60 engines had cam walk problems that would put heavy load on dist gear and shaft at high RPM.
If Isky cam is installed with newer cam bearings and late timing gear should be no problems.
My current beast is apart. I will take a look at dist gear and report back. TJR
  1. Cam Bearing Interchangability - Mike G. on Apr 28, 7:15 PM
    1. Previous Post Source - KULTULZ on May 7, 5:16 AM
      1. KULTULZ, I posted block bore ID for cam bearing - gary534 on May 7, 6:06 AM
        1. CORRECT... - KULTULZ on May 8, 6:25 AM
