WELL DUH!
June 11 2004 at 4:30 AM
from IP address 69.140.63.191
Response to It's Actually All My Fault...
SHEESH!
Here is a photo of a 58 MERC 430 engine mounting pad (Thanks Chris!);
This is from Theo's album on this site of a 60 LINC (The mounting pad appears to be different);
This is a photo of a 62 LINC bellhousing. You may be able to get an idea of a later mounting pattern (if there is actually a difference);
Print these out and send them to the guy with the later 430 and if the mount pads are the same, I would say you are OK.
  1. Obviously,... - Theo on Jun 11, 5:16 AM
    1. HOUSTON...We Have A Problem... - KULTULZ on Jun 11, 5:54 AM
      1. Hello crew, you can unlock your belts, bug is fixed...... - Theo on Jun 11, 8:26 AM
        1. Nope...Completely Different... - KULTULZ on Jun 11, 9:48 AM
          1. Another Example... - KULTULZ on Jun 11, 9:54 AM
            1. Not sure if there is a misunderstanding here....... - Theo on Jun 11, 12:01 PM
              1. Skirt Molds - KULTULZ on Jun 11, 3:41 PM
                1. Easy to answer.......... - Theo on Jun 11, 10:54 PM
              2. Re: Not sure if there is a misunderstanding here....... - jc on Jun 11, 9:31 PM
                1. The T-Bird 430 block is probably your best choice....... - Theo on Jun 11, 11:17 PM
                  1. 462 CR - KULTULZ on Jun 14, 6:31 AM
                2. Glad We Straightened That Out... - KULTULZ on Jun 13, 1:54 AM
                3. 462 compression vs 430 - Jeffer on Jun 21, 1:03 PM
                  1. You're right,....... - Theo on Jun 22, 1:39 AM
            2. Tapping and threading new holes into the mid skirt............. - Theo on Jun 11, 12:56 PM
              1. Photo Hosting - KULTULZ on Jun 11, 3:44 PM
                1. Engine mounts on the T-Bird FE.......... - Theo on Jun 11, 11:22 PM
                  1. FE? - KULTULZ on Jun 12, 4:55 AM
                2. T-Bird engine and various FE motor mount bolt patterns....... - Theo on Jun 12, 1:26 PM
                  1. Design Evolution - KULTULZ on Jun 13, 9:08 AM
                    1. sorry guys and especially theo, but that FE info is all backwards.... - hawkrod on Jun 14, 7:16 AM
                      1. Twist again.... - Theo on Jun 14, 4:18 PM
                        1. that one is too easy.... - hawkrod on Jun 14, 4:50 PM
                          1. Yes, now I can see it too,....... - Theo on Jun 14, 11:38 PM
                          2. Pics above zensored and corrected n m - Theo on Jun 15, 11:17 AM
