Design Evolution
June 13 2004 at 9:08 AM
from IP address 69.140.63.191
Response to T-Bird engine and various FE motor mount bolt patterns.......
"So far I found two different engine mount bolt patterns used in three different ways.
1. 4 bolt engine mount bolt pattern w. all...four bolts in usage
2. 4 bolt engine mount bolt pattern w. only three bolts in usage
3. 2 bolt engine mount bolt pattern w.........two bolts in usage (truck ??)"
1958-1964 Mounting Pad
http://hotrodders.com/gallery/data/500/422FEmotormountpad_58-64.bmp
1965- Mounting Pad
http://hotrodders.com/gallery/data/500/422FEmotormountpad_65up-thumb.bmp
The change was made with the introduction of the FT Series (330/361/391). My guess is it had something to do with the more secure mounting of the truck engines even though most used front and rear mounts in heavy chassis applications.
  1. sorry guys and especially theo, but that FE info is all backwards.... - hawkrod on Jun 14, 7:16 AM
    1. Twist again.... - Theo on Jun 14, 4:18 PM
      1. that one is too easy.... - hawkrod on Jun 14, 4:50 PM
        1. Yes, now I can see it too,....... - Theo on Jun 14, 11:38 PM
        2. Pics above zensored and corrected n m - Theo on Jun 15, 11:17 AM
