Early MEL Camshafts
July 19 2008 at 2:49 AM
from IP address 69.140.42.35
Response to Here is my best guess -
There was more than one camshaft used on the 58 as MEL had engineering troubles. The first issued was replaced by the 383 MERC (Lo Torque and Hi Torque used the same cam) as lift was too high with resultant spring bind. The CR was later dropped with a higher deck block.
If you can't plot what you have with a degree wheel and micrometer, most cam companies can plot it for you. Best option is to send it to OREGON CAMS for upgrading.
The SUPER MARAUDER option used the same camshaft (later).
On a previous post here, I gave the cam events.
  1. Hint as to the cam spec post? Cant find! - WerbyFord on Jul 19, 10:33 AM
    1. CAM SPECS - KULTULZ on Jul 20, 2:47 AM
      1. Yes if you can post it would help I'm really guessing - WerbyFord on Jul 20, 8:32 AM
        1. Cam Events - KULTULZ on Jul 22, 1:31 AM
  2. cam grind options - tom cassidy on Jul 19, 7:18 PM
    1. OREGON CAMS - KULTULZ on Jul 20, 2:17 AM
