Performance Camshafts
May 20 2004 at 2:14 PM
from IP address 69.140.62.242
Response to cam upgrade
I don't know about the cam on E-Bay as no manufacturer or warranty is mentioned. As for the other, it is most likely a stock regrind for OEM replacement.
You need to speak with specific cam manuafacturers about their ability/willingness to grind a cam for you. They will get together with you to discuss how far you want to go and how much you are willing to spend. A lot also depends if anyone has any new blanks available. If not, a regrind of a stock cam is the only option.
Use a search engine for ISKY, CRANE, COMPETITION CAMS and CROWER for a start. MEL came through with hydraulic tappet cams so any type of upgrade is going to cause a resultant upgrade in the valvetrain. It all needs to be planned out.
Click on URL;
http://www.egge.com/
  1. Pistons and cranks - jc on May 20, 3:02 PM
    1. Reground Camshaft - KULTULZ on May 20, 4:45 PM
      1. Regrinding a cam is usually a clean up of the lobes........ - Theo on May 20, 5:59 PM
      2. Re: Reground Camshaft - jc on May 21, 11:39 AM
        1. Hey that's interesting.......... - Theo on May 21, 1:26 PM
        2. Hi JC - Anonymous on May 21, 3:57 PM
          1. Re: Hi JC - jc on May 21, 6:47 PM
          2. Honing Plates - KULTULZ on May 22, 7:39 AM
            1. These odd honing plates would probably cost a $... - Theo on May 22, 2:45 PM
              1. Cost of Plates - KULTULZ on May 22, 3:07 PM
                1. Oh, torque plates are essential.... - Theo on May 22, 3:14 PM
          3. Re: Hi JC - jc on May 24, 8:10 PM
            1. Hi JC - JL on May 26, 6:39 AM
              1. Re: Hi JC - jc on May 27, 11:45 AM
