Hi Folks,
how can i check if my Timing gear ist worn out, in my MEL462? can I hear it?
Thank in advance
Tom
Timing Gear?
LandCruiser
- Music instruments you're playing: A little bit guitar, that i build by my own
Re: Timing Gear?
Hi,
It is done visually, you will need to remove the water pump to see....
Cheers Angelo
Cheers Angelo
LandCruiser
Re: Timing Gear?
Thank You, Angelo!
LandCruiser
Re: Timing Gear?
The ODO say´s 53000 and it could be ok, the "Gutachter"said.
