PCV valve set up for 430
Post by Shelby#18 » Tue 9. Jun 2009, 16:09
First don't shoot me! :lol:
I'm sick and tired of my older cars producing hazy fumes from the engine compartment when coming to a stop (which in L.A. we do a heck of a lot.) I've already addressed the issue on my '59 Ford vehicles by putting a plate under the carb, and attaching a threaded pipe to the back of the intake manifold. Now I'm moving on to the Lincoln's. Has anyone else done something similar? I can do the under the carb plate, but where is a place to hook up the other end without drilling wholes?
Re: PCV valve set up for 430
Post by Theo » Wed 10. Jun 2009, 04:56
Rick, how about using a snout type oil filler tube cap and rout a rubber tube right into the carb base plate? I think I have once purchased a chrome cap w. snout from a Ford dealership many years ago.
I would probably not be a perfect PCV solution but should work fine to some extend. It's cheap and no extra holes are needed.
Post by KULTULZ » Wed 10. Jun 2009, 06:59
To properly vent a 58/60 MEL to PCV, the internal road draft tube has to be blocked off. The best place for the actual draw would be at the rear of the valley cover as on the 61/ .
61/ PCV Provision- Vally Cover
61/ Internal Air Baffle
Post by Shelby#18 » Wed 10. Jun 2009, 12:58
Thanks Kultulz,
That's exactly what we were thinking, but couldn't find any place already threaded. The next question would be did you route that to the carb.? And if so did you use a spacer plate?
All the best...
Rick
Staff Sergeant
Staff Sergeant
Post by reijerlincoln » Thu 11. Jun 2009, 02:16
58/60 MEL still had the internal road draft tube that just blows all the gasses from the crank into the environment? I thought those became illegal in the early fifties.
Post by Shelby#18 » Thu 11. Jun 2009, 10:56
I also have a '61 falcon were the draft tube is exhausted straight to the environment.
Post by KULTULZ » Sat 21. Aug 2010, 15:50
1961 CA
1963 49 STATES
Post by KULTULZ » Sat 21. Aug 2010, 15:53
Easiest routing (vacuum source) would be a carb spacer.
Shown is 1962 430 routing.
Post by KULTULZ » Sat 21. Aug 2010, 23:27
This is the rear vent (road draft) in the 58/60 engine that needs to be removed and replaced with an expansion cup to retro-fit PCV.
There is also a road draft tube at the bottom that needs to be removed and replaced with a cup
keithol
Post by keithol » Sun 22. Aug 2010, 14:27
How about routing a suitable hose from the road draft tube outlet at the bottom of the block , around the back of the block to your carb spacer plate ? This would still get you to your proper evacuation point without tearing into the engine and having to replace gaskets and the valley cover, which I am sure is hard to find . I'm sure everyone here is talented enough to hook it up without making it look too tacky. I just have to add, for me the number one priority is not the smelly fumes, but the damage done by water vapor and other chemicals without adequate ventilation of the crankcase. Before PCV we had to dig pushrods & lifters out of the valleys etc. up to two inches deep with sludge.
