Mel motor and tran
Mel motor and tran
Well guys i got a 59-61 t-bird with mel motor and a mercury Ill part them out Im not sure of the size of them I also have 3-5 bellhousinngs for mel and more stuff the tbir has a 4 barral intake with holley carb pat
Re: Mel motor and tran
Can you be more specific? You have a BIRD and MERC w/MEL that you are willing to part?ltman wrote:
Any chance of photos and where you are located?
Im in WV The tbird motor is complet minus carb The mercury motor is complet with 2 barral carb both has had weather in them at some pont But they should be some parts that can be salvaged from them Ill try to get some pic up in the next day or so
Hears a pic of the mercury wagon can any 1 tell me what year this is i got a good set of fender skirts for it The date code on the t bird intake is 7AP EDG-8425-A
CORRECTION! It is a 430 2V.
If the BIRD engine has been sitting out in the weather without a carb, it doesn't have that much value. What amount were you thinking and about what part of WV are you in?
- Attachments
- 1960 MERC Colony Park_1.jpg (40.28 KiB) Viewed 38539 times
Im in southern WV I dont no what these motors are worth Ill sell them for a resonable price
How far from Princeton are you and I assume they are still in the car(s) so will you or the buyer pull them?ltman wrote:
