| still stallingSeptember 27 2008 at 7:52 PM | Ray (no login) |
Response to Also, |
| After switchimng the carbs I'm stalling on the port engine now so I believe it to be a carb issue. I pulled both carbs off , took them apart and cleaned them both. Floats appear to be good. I want to get rebuild kits but seem to have a problem finding the right kit. The carbs are Carter AVS number 6117, however when I look up the carbs they look like Carter AFB's. Not sure which kit to use and I cannot find a supplier of kits in NY or NJ metro area.
Ray |
| Responses |
