Trans codes
December 9 2007 at 3:17 PM
  (Login topcat53)
from IP address 24.140.58.44
Response to Transmission Selections
Sure appreciate the listing. The dual range all have different prefix and suffix letters. I assume the 7000 units are all large case? I know there were pushbutton and column shift options. Do you suppose that's what indicates?
I have a 58 pushbutton trans. the only numbers I found on it was PBB-7006J,no prefix. I thought That I could use it,but not familar with the park cable operation,if I could just eliminate cable. Also,the levers on trans are different. Do you know anyone that if knows if levers can be swapped?It came from a 58 Park Lane.
Not knowing details,that's why I decided to look for another trans that had a column shift. Any suggestions you may have would be appreciated. Tom
