Pan Interference
April 28 2006 at 4:50 AM
from IP address 69.140.42.35
Response to roller lifter interference
You must slightly relieve the pan where those lifters hit (if they do on your application).
If using an ISKY roller, one can also use FE roller LIFTERS (aftermarket) and springs. Also, FE adjustable rocker arms and solid lifter rocker arm shafts. Check springs for bind according to lift of cam.
