Cylinder Head Identification
June 15 2005 at 1:04 AM
from IP address 69.140.54.63
Response to Re: Early MEL Valvetrain Problems
Somewheres on the head (most likely under the rocker cover) should be a seven character (numeric) casting no. along with a date cast code. Hopefully, this ID No. will correspond to the Service PN and the head can be identified.
Did you actually see where the valves were touching the pistons at teardown?
  1. Re: Cylinder Head Identification - Anonymous on Jun 15, 10:08 AM
    1. Valve Interference - KULTULZ on Jun 16, 3:52 AM
      1. Re: Valve Interference - derek on Jul 27, 7:55 PM
