462 C6
December 9 2004 at 4:31 PM
from IP address 69.140.35.248
Response to Re: 462 Should drop right in
The bellhousing pattern is different on a 462 and it's mating C6;
Also, the output shaft and yoke on the slabside Twin-Turbo (LX) are unique and you would have to modify this feature on a later C6 swap.
The 460 used in 1968 required frame modifications from the factory so you would have to allow for that in your 65 LINC also if you decide to go that way.
  1. Re: 462 C6 - Bob on Dec 9, 7:36 PM
    1. 460 Hood Clearance - KULTULZ on Dec 9, 7:50 PM
      1. Re: 460 Hood Clearance - Thanks! - Bob on Dec 9, 11:08 PM
