460 Hood Clearance
December 9 2004 at 7:50 PM
from IP address 69.140.35.248
Response to Re: 462 C6
There should be no clearance problems as long as the engine is cradled properly and uses the stock intake. The slabside hoodline is really low. Where you see difficulties is when an owner would use an aftermarket aluminum intake with a raised carb pad.
Here's some more information;
http://www.network54.com/Forum/message?forumid=257364&messageid=1083552986
  1. Re: 460 Hood Clearance - Thanks! - Bob on Dec 9, 11:08 PM
  2.
