| oem 58 supermauraderAugust 10 2004 at 10:55 AM No score for this post | jeff (Login jeffhamman) from IP address 68.97.215.125 |
Response to 462 Retrofit |
yes i was lucky to find it , it has the ford holley carb pattern. unfortunatly I dont have any thing else such as the special fuel pump or carbs, what I have done was to get 3 normal 2 bbl holley carbs and add the early style fuel bowls so the airhorns would clear. I was also lucky to reach another individual that had factory pictures. It looks pretty close to original except I am running mechanical secondaries and adapted a normal oval ford style air cleaner to the three carbs. Ive thought about duplicating the look of the aircleaner and fuel pump. I ve got a picturs (2nd generation photocopies) showing the lincoln version and the mercury version and the optional finned valve covers.I bought this item back in 92 when I had a 1959 430 tbird. I needed to sell but kept the intake. | |
| Responses- MERC-LINC Version - KULTULZ on Aug 11, 12:54 AM
- 430 supermaurder - jeff on Aug 16, 5:24 AM
- :) - KULTULZ on Aug 17, 6:05 AM
