Hi,
I'm wondering what kind of transmission fluid to use in my '62 Lincoln Continental? It has the original dual range turbo drive transmission, and the shop manual specifies Type A fluid (now obsolete). I read another post on this site that references replacing the fluid with Dexron/Mercon, however I've also read that Type F fluid is specified for all Ford Automatic Transmissions Prior to 1977. My tendency is to use Type F fluid, has anyone else done this?
Comments appreciated!
Joe
'62 Lincoln Transmission Fluid Question
Re: '62 Lincoln Transmission Fluid Question
I've always used contemporary trans fluid without problems.
