I have from a 1966 Lincoln:
462 Block
useable pistons
California heads (have the threaded ports for the thermactor system that can be plugged.)
California style timing cover with the oil fill on the top, including the cap.
Flexplate
rocker covers and oilpan.
Intake manifold
Both exhaust manifolds, studs intact and no cracks.
A/C bracketry, no compressor.
Crank mount power steering pump.
Power steering reservoir.
Harmonic balancer.
Water pump, not leaking, but older.
Transmission spacer plate.
Good condition rebuilt C-6 transmission with 1,500 miles appx. with torque converter.
E-mail at Lincoupe66@nospamyahoo.com
Take away the nospam.
Thanks! Rob
edited 8 JAN '09 to correct email address.
MEL Parts - PICTURE WARNING
66Lincoupe
66Lincoupe
Re: MEL Parts
Exhaust manifolds; all of the threads are good in every hole and on every stud - I chased each one. The passenger side has been surfaced and looks crack - free. I just cleaned the driver's side and it looks good, too. Because I did not remove the studs I didn't surface the driver's side manifold:
Harmonic Damper:
Flexplate:
6 blade fan:
Misc Brackets; AC bracket to head and AC bracket to compressor, alternator to block and adjuster, coil mount, trans crossmember:
Throttle and trans bellcranks:
Trans, shim and access panel, and torque converter. Worked well and was supposedly rebuilt but no paperwork:
I have more little stuff, but it's still boxed away. I've been here a little more than a year and still haven't unpacked all of my shop. Moving is awful.
If you are interested in anything, please make an offer - even if it seems silly.
If you see something you want and want to trade - I need a Hood ornament, one horn switch (the long bar,) an Ivy gold front seatbelt (buckle side,) and armrest boxes in any color can be sedan, convertible or coupe - I can make holes for the lights. For a 1966 Continental
Harmonic Damper:
Flexplate:
6 blade fan:
66Lincoupe
Re: MEL Parts - PICTURE WARNING
Okay, here's an update:
The driver's side exhaust manifold is sold
the power steering pump is sold
The rest is still available!
66Lincoupe
Well, the car is up for sale (again!) So most of these parts will be unavailable if the car sells soon.
I do have a set of engine and Transmission mounts for a 1966 Lincoln 462/C6 in very good used condition.
66Lincoupe
The oil cap and transmission mounts have been sold.
66Lincoupe
Well, after repeated attempts to sell the car I am keeping her. I will be using the parts so they will no longer be available.
Thank you!!
Thank you!!
Hi, I need a harmonic balancer. do you still have one for sale? thanks, call me at 712-733-8809 Henry
