Originally postet by "bigwillis "
April 19 2005 at 6:44 AM
from IP address 70.177.237.243
i have a 77 ford f-100 with a 462 from a 66 lincoln in it. is the trans just a standard C6 or is it unique to these engines? having problems with mine and just not sure if i should just rebuild or replace. thanks
C6 trans questions
Re: C6 trans questions
462 C6
The main case/mounting bell was unique to the 462.
- alternate
- Editorial Group
compatible parts
are parts for the ford c6 (such as rebuild kits, torque converter, pans) compatible with my c6? it seems hard to find anything specifically for the 66 462 trans
Maybe?
I believe the MEL C6 is almost identical to the regular C6 other than the main case, and that only differing on the bolt pattern to the block.
Is it possible you have a TWIN-TURBO? Is the bell and main case one piece (aluminum) or two separate pieces? Do you see a metal assembly I.D. tag on the servo cover?
I know this is an old thread, but just for future reference.
The trans is the same as any other early C6 except, the case, tailhousing and output shaft are unique. Case for bolt pattern, tailhousing for mount and three spline yolk with linear bearings.
The tailhousing and output are a direct swap to any other C6.
Also original lincoln forward clutch friction plates are a coarse spline as are other early C6 units. This is easily updated to the later fine spline by using a later input planet internal gear.
