Any Manual for MEL engine Firing Order in a Chris Craft Boat
Finally figured this out on this motor but still do not know the firing order, took me a min to under stand the right hand -counter clockwise , a chain would turn the same way but gear to gear is rh cc, was there a manual i could buy for this motor application from chris craft
Easiest way to get a manual(s) is to go here:
http://www.ccmanuals.com/
Tom has assembled all of the manuals you see for $10.00 on CD ... I have some paper copies, but they are sometimes repro's that are not very good, so if you get this CD it will cover most of what you need.
