1958 383 Mercury Holley carb info ???
- trident
- Editorial Group
- Music instruments you're playing: nukulele
November 21 2004 at 4:40 PM
I am building a 4V Holley carb from a 1958 Mercury 383. The Holley carb number is List 1616. Does anyone have any info on this carb such as the correct jet sizes, tips, and upgrades for todays low octaine fuel?
Thanks,
Clayton
Thanks,
Clayton
Re: 1958 383 Mercury Holley carb info ???
No score for this post November 22 2004, 11:25 AM
There Were Three 4150 Holleys Used On The 383. On the airhorn usually below the LIST NO should be stamped a CARB ID NO., EDG C, EDG E OR EDG D.
You need this ID No. to properly choose the setting specs for the carb. Does your overhaul kit give you this information? If not, I can scan the info from the 58 MERC Shop Manual for you.
- trident
- Editorial Group
No score for this post November 22 2004, 10:47 PM
The carb is an 842 EDGE LIST 1616. I don't have a kit for it. Actually I have lots of new Holley parts and I am pieceing it all together. If you could scan that for me I would really appreciate it. I hope I have the right jets in it. With the 52 primaries and 59 secondaries.
Thanks much,
Clayton
Thanks much,
Clayton
No score for this post November 23 2004, 10:39 AM
#52 and #59 Are Correct - 0/5000FT Altitude
I hope to have it scanned and posted by Fri.
Gary
Gary
No score for this post November 28 2004, 4:39 AM
Clayton...I Am Sorry...
I don't have a flat scanner so I was going to use a friend's over the holiday but that didn't work out. I will try and have the pages up by tomorrow.
No score for this post December 3 2004, 12:39 PM
Copies In Mail... n/m
No score for this post December 5 2004, 5:51 AM
PO Said Ten Day Delivery...Sorry...n/m
- trident
- Editorial Group
No score for this post January 10 2005, 7:49 PM
I have almost finished this Holley carb (EDGE list 1616) but one thing has bothered me some what. The air bleeds on the primary side. The two inner primary air bleeds are missing, there is just a hole. Is this the way they came from the factory? I've never heard of these falling out and they are both the inner ones which almost makes it seem original. Hmmmmmmmmm?
Thanks,
Clayton
claykuch@telus.net
Thanks,
Clayton
claykuch@telus.net
- triton_750
- Editorial Group
No score for this post May 2 2005, 8:29 PM
1.19 4100
Hey claton i've got a motorcraft 4100 with 1.19 venturi
bores. they used this carb on "high torque" 383's in 58 only.
4100freak
1.19 4100
4100freak
WerbyFord
- Music instruments you're playing: Clarinet and Sax but not lately
Not sure how the 1616 bleeds were stock, but on my List 6390 (also a 390cfm Holley like your 1616), the inner (main) bleeds are zero, ie not drilled at all. No bleed, at least at that location. The outer (idle) bleeds are about .067" in the usual brass insert.trident wrote:No score for this post January 10 2005, 7:49 PM
Thanks,
Clayton
claykuch@telus.net
Maybe yours were undrilled also, like mine, and somebody drilled them out to lean things out at high speed?
Perhaps somebody knows the spec for the air bleeds on the 1616 to solve this mystery.
The 1616 seems a bit small at 390cfm for a big 383/312hp rated engine but then again it is a heavy car. If you can't get that carb running right you might try a larger carb like a 450cfm or 550cfm Holley or a 4100 Autolite 1.12 or 1.19
