Distributor Interchangability
Discussion about ignition, timing, points, conversions and div. tune up recommendation.
Senior Airman
Senior Airman
Re: Distributor Interchangability
Post by Chris430 » Wed 18. Apr 2018, 04:31
Chris430 wrote:
Sat 28. Nov 2015, 21:12
I have a couple of distributors out to compare. The left distributor is FEU-12127-J from a 1958 332 FE, the right FEW-12127-H from a 1959 430 MEL. They use the same FEK-12378-B vacuum advance and seem to be the same internals. There is a difference in gear to seal distance with the FE being greater. The 332 gear is 1.042 o.d. The 430 gear measured 1.052. The shaft diameter was different by .0002, I don't know if there are different shafts or they are just on extreme ends of tolerance.
Pictures reposted. Visible in original post.
Return to “MEL Engine Ignition and General Electrical Topics”
