New MEL camshafts
Exchange knowledge and discuss MEL engine related aftermarket engine parts like cams, rods, chains, intakes and lots more.
Re: New MEL camshafts
Post by Theo » Mon 3. Oct 2011, 15:13
It's an old thread which I saved from the old forum.
res0rli9
Post by res0rli9 » Sun 27. Nov 2011, 09:11
What is the firing order on the the Mel engine?? are they the same as the flat head as to why the are so smooth.
Post by Theo » Mon 28. Nov 2011, 07:15
Firing order is 5 4 2 6 3 7 8
Check out this chart
http://www.ford-mel-engine.com/viewtopi ... +order#p31
430 6V
Post by 430 6V » Thu 15. Mar 2012, 20:26
I've had new grinds (technology) put on original cams with good success so far. Early Chryslers and Mels.
Reginds are a case of mind over matter. If you don't mind it doesn't matter. :lol:
cowboy.2010
Gender: female
Post by cowboy.2010 » Thu 25. Oct 2012, 15:01
Hey guys I was just letting you all no I would deffently be interested In a few cams. You have my support if it was ever a go to where it can be done :) I am planning on building a 462 and will need a good cam and possibly some blanks to save for other engines.
Return to “MEL Engine Aftermarket Parts”
