Mel motor and trans
ltman
Mel motor and trans
Post by ltman » Fri 2. Jan 2009, 10:09
Well guys i got a 59-61 t-bird with mel motor and a mercury Ill part them out Im not sure of the size of them I also have 3-5 bellhousinngs for mel and more stuff the tbir has a 4 barral intake with holley carb pat
KULTULZ
Re: Mel motor and tran
Post by KULTULZ » Fri 2. Jan 2009, 14:12
Can you be more specific? You have a BIRD and MERC w/MEL that you are willing to part?
Any chance of photos and where you are located?
ltman
Post by ltman » Fri 2. Jan 2009, 15:35
Im in WV The tbird motor is complet minus carb The mercury motor is complet with 2 barral carb both has had weather in them at some pont But they should be some parts that can be salvaged from them Ill try to get some pic up in the next day or so
ltman
Post by ltman » Fri 2. Jan 2009, 22:22
Hears a pic of the mercury wagon can any 1 tell me what year this is i got a good set of fender skirts for it The date code on the t bird intake is 7AP EDG-8425-A
KULTULZ
Post by KULTULZ » Sat 3. Jan 2009, 01:09
The MERC is a 1960 Colony Park. If 2V, the engine is a 383.
CORRECTION! It is a 430 2V.
If the BIRD engine has been sitting out in the weather without a carb, it doesn't have that much value. What amount were you thinking and about what part of WV are you in?
1960 MERC Colony Park_1.jpg (40.28 KiB) Viewed 17108 times
ltman
Post by ltman » Sun 4. Jan 2009, 19:43
Im in southern WV I dont no what these motors are worth Ill sell them for a resonable price
KULTULZ
Post by KULTULZ » Sun 4. Jan 2009, 22:46
How far from Princeton are you and I assume they are still in the car(s) so will you or the buyer pull them?
