Anybody know where I can find some MEL cylinder head flow charts? Stock or ported? Or any general info on what they flow? What castings are better than others? Any info would be appreciated.
thanks,
paulie
Re: MEL cylinder head flow
Hey Paulie, glad to see you here my friend. I have no flow charts and I guess they're very rare. The 1958 cylinder heads have huge intake runners. The ports are gigantic. I think they are a bit taller than the tallest FE intake ports.
I believe from 1959 on the Intake ports were downsized for better velocity.
plovett
- Music instruments you're playing: I have a mandolin, but need someone to teach me how to play it.
Thanks Theo! I was hoping to build some cyberspace MEL's in my dyno simulator. But it's all for naught without flow numbers. I'm guessing the MEL has quite a bit of power potential even without aftermarket support. The '58 heads sound interesting. If I find some info I will post it here.
paulie
paulie
Yes, that would be interesting. The good thing about the flat chamberless MEL heads is that they have no restriction from valve shrouding. I assume that they have similar flow characteristics as tall port 427 heads.
