1962 Galaxie Starliner engine
lincoln62
Post by lincoln62 » Sun 24. Jan 2010, 11:54
i can vuagly remeber(or spell!!) a 1962 issue of Hot Rod magazine in which Ford or maybe Mickey thompsen for Ford, put a 1961 starliner roof on a 1962 Galaxie. They put a large,472 or so cubic inch engine in it and took it to Bonneville. I can't remember if it was a large (472 or534) ford heavy truck engine, a MEL, or an FE. anyone have an issue of this article, or remember it? thanks.
Ted
Re: 1962 Galaxie Starliner engine
Post by Ted » Mon 25. Jan 2010, 06:54
Here are some details on the 483 CID engine used in the '62 Ford that ran at Bonneville per the Jan 1963 issue of Car Life magazine.
Bore: 4.23"
Stroke: 4.3"
Compression ratio: 12:1
Dual 4 barrel Holley carbs
2.67:1 rear gear ratio
The Galaxie chassis started out as convertible and had a Starliner roof grafted on.
Best speed was 176.978 mph and two way average was 172.26 mph.
46 national and international records were set in Class B.
Post by Theo » Mon 25. Jan 2010, 06:57
Any photos?
Ted
Post by Ted » Mon 25. Jan 2010, 07:07
Here's a pic of the car.
Lorenzen 1962 Ford Bonneville
Post by Theo » Mon 25. Jan 2010, 08:07
Ooh, that's the one? I remember having seen it years ago. Thanks.
lincoln62
Post by lincoln62 » Mon 15. Feb 2010, 15:33
I forgot Fred Lorenzen drove it, Hoolman & Moody built it. Man, that is fast for a square 62 ford!
