tranny swap
mooseb
tranny swap
Post by mooseb » Sun 3. Jan 2010, 12:11
Hi i am new to this site. I put 1958 430 in a 50 ford convt . My question is the tranny is bad so I think if I understood was that I can put a early FE C6 tranny in there mooseb
Re: tranny swap
Post by Theo » Mon 4. Jan 2010, 03:26
Check out Ted's comment on a similar topic here
viewtopic.php?f=3&t=345
lincoln62
Re: tranny swap
Post by lincoln62 » Sun 24. Jan 2010, 11:29
any C-6 from a FE (352,360,390) will do. Car or pickup. A C-6 from a 3/4 ton pickup is easy to located and will probably have the heavier clutches. I am speculating here, but MAYBE an FMX from a 70's Ford will bolt to the cruiseomatic bellhousing??? Anyone know?? Hope this helps, Henry.
Return to “MEL Transmission”
