hello all sorry ive been a flake on getting back to people with questions and such im just finalizing a big realestate deal right now for my new shop facility and have been spread way to thin to imagine..( i know every body has excuses and you know what) BUT I HAVE THE OPPORTUNITY TO FINALLY FINISH OFF MY GEAR DRIVE TIMING SET AND THE MECHANICAL ENGINEER THAT IS GONNA DO THE FINAL PHASE OF THE R&D IS NEEDING SOME INFO THAT I DO NOT HAVE REDILY AVAILABLE AND DONT HAVE THE TIME TO GATHER BUT IF SOMEONE OUT THERE COULD GET THIS TO ME I COULD FINALLY GET THIS DONE.... HERE IS A LIST OF WHAT I NEED AND IF ANYONE READING THIS COULD SPREAD THE WORD SO WE HAVE A BETTER CHANCE OF GETTING IT ALL THAN I THINK WE ARE ABOUT A MONTH OUT OF HAVING THE FIRST UNITS COMPLETED.:
1. I NEED THE EXACT DISTANCE BETWEEN CENTERS OF THE CRANK AND CAM SHAFTS.
2. I NEED A 2D FILE OF THE ORIGINAL TIMING GEARS SO BASICALLY A TRACING OF THE TWO GEARS BUT IN DIGITAL FORMAT LIKE DXF OR PDF PERFERABLY TO EXACT DIMENTIONS
3 ANY INSIGHT INTO ANY DIFFERANCES BETWEEN THE MODEL YEARS ON THESE TWO ASPECTS OR CONFIRMATION THAT THEY ARE ALL THE SAME... IF ANYONE HAS THIS INFO AND WANTS TO CALL ME WITH QUESTIONS PLEASE CALL 575-202-0334 AND ASK FOR BRIAN..... AND AS FAR AS THE FILE OF THE ORIGINAL GEARS BASICALLY SOMEONE WHO HAS A NEW SET OF GEARS AND CAN TRACE THEM WITH A FINE TOOTH PENCIL AND SCAN THEM INTO A SIGN MAKING SOFTWARE OR INTO AUTOCAD AND SAVE AS A .DXF AND MAKE SURE THAT THE FILES ARE SETUP WITH EXACT DIMENTIONS AND TOLERANCES THIS IS WHAT I MOSTLY NEED... AS I DO NOT HAVE AN UN INSTALLED SET OF GEARS AND I KINDA NEED THIS INFO BY FRI TO MAKE IT WORK WITH THIS GUYS SCHEDULE..... LET ME KNOW!!!!!!!!!!!!!
Need a couple of dimensions
bestrada11
