Re: Chris Craft 430ies
Post by Theo » Sun 17. Jul 2011, 13:31
Chris Craft crazy wrote:I wish we had the trucks that Europe has... We lack those smaller diesel trucks, and substitute big ass gasoline pickups that get ten miles to the gallon. arggh.
Yeah, they're not spectacular trucks, but do their job fine. Diesel is currently 1,40 Euro per liter. You get the picture.
Chris Craft crazy wrote: Theo, dude, that's a lot of iron. I'm sure it was all very important to save... :mrgreen:
(looks like my shed)
:oops: .....seems you're with my folks, eh! Aftermarket trick parts are probably cheaper than my old fashioned resto plans Also my plans rarely became true. Maybe I need to wait another decade or so,....good stocks or bad stocks. Maybe I just don't want to know. :)
Post by Theo » Mon 18. Jul 2011, 00:18
Peter, check out this article and the photos regarding valve tip to rocker arm tip geometry
http://www.pauter.com/RockerInst.htm
Post by Theo » Mon 18. Jul 2011, 00:35
Also keep in mind that you need to adjust the right lifter pre load. In the case of adjustable rocker arms with hydraulic lifters it's about setting to the right "lifter pre load". On solid lifters it's all about "valve lash" adjustment.
Just in case you don't know.
Set your lifter pre load one by one by bringing each cylinder to its' compression stroke. That's when the piston is appx. at TDC of the compression stroke (Top Deck Center) and both valves are fully closed at the same time. Don't confuse it with the exhaust stroke.
Adjust both valves by tightening the lash adjuster while you spin the push rod between your finger tips....until you feel a slight drag(called zero lash). Then tighten the lash adjuster and additional 1/4 - 1/2 turn as this equals about appx. 0.030" pre-load on the lifter. Keep in mind that you won't have that slight drag if your lifters are not pre filled with oil.
If for some reason you decide not to soak your lifters with oil over night, determining the zero lash point will have to be visually w.or w/o a dial gauge and with some feel of your fingers.
Check out this video. Be aware that the demo engine has a different firing order. I link it because the lifter pre load thing is good for any hydraulic lifter engine exceot that the number of turns on the adjusting nut may vary depending on the brand of shaft mounted rocker arm.
viewtopic.php?f=58&t=84
Post by Theo » Mon 18. Jul 2011, 00:41
Found this on my HD. Maybe of some value for you.
128.pdf
(276.97 KiB) Downloaded 710 times
195.pdf
(73.42 KiB) Downloaded 704 times
510e.pdf
(1.11 MiB) Downloaded 666 times
Post by Chris Craft crazy » Sat 23. Jul 2011, 19:03
Theo, remember this engine is S O L I D lifters..... I have the valve lash specs. :mrgreen:
Thanks for the comp cams stuff... I will post my set up when I get the spacers.
Post by Theo » Mon 25. Jul 2011, 07:14
Oooh, sorry my head is kaputt.
Post by Chris Craft crazy » Tue 2. Aug 2011, 19:25
I received my Harland sharp spacers, and a couple of needed to be cut down, so I chucked them up and took the difference off with my old Atlas metal lathe. Nice setup, and very simple.
FEfinaticP
Command at Sea
Command at Sea
Post by FEfinaticP » Fri 26. Aug 2011, 18:51
That's a boy dog for sure !
Here is a photo of another one, happens to be aboard a 38' Chris Craft Commander (fiberglass) of 1965, 275 horse version.
http://img.photobucket.com/albums/v472/ ... C00280.jpg
http://img.photobucket.com/albums/v472/ ... C00276.jpg
This is essentially the same engine as a 430 but the 431 designation was used when they (CC) went to the updated cooling system.
A pair of these "big dogs" would push a 38' 20,000 pound fiberglass Chris Craft Commander up to 30 miles per hour!
Nashville, TN
FEfinaticP
Command at Sea
Command at Sea
Post by FEfinaticP » Fri 26. Aug 2011, 19:08
A few more photos since I know you guys are the ones who will appreciate these more than anyone!
http://img.photobucket.com/albums/v472/ ... C00281.jpg
http://img.photobucket.com/albums/v472/ ... 237616.jpg
http://img.photobucket.com/albums/v472/ ... C00277.jpg
Here are some photos of what I think are the older style 430.
http://img.photobucket.com/albums/v472/ ... 003754.jpg
Some performance data
http://img.photobucket.com/albums/v472/ ... r11177.jpg
Hope you all enjoy the photos!
best,
Post by Theo » Sat 27. Aug 2011, 05:01
Definitely great photos Paul. Tank you for sharing. May I steel them by copieing and uploading them to remain local at the forum server. This way they wouldn't get lost in case the owner removes or relocates his photo collection from the other server.
