Lincoln Brake Parts 1956 - 1960
Post by 59lincolnrag » Mon 17. Aug 2009, 11:55
Part# Loc. Description Application Qty
H2035 Front&Rear ADJ. LEVER - LEFT All 2
H2035-2 Front&Rear ADJ. LEVER - LEFT All 2
H2036 Front&Rear ADJ. LEVER - RIGHT All 2
H2036-2 Front&Rear ADJ. LEVER - RIGHT All 2
H1520 Front&Rear ADJ. SCREW ASSY. - LEFT All 2
H1520-2 Front&Rear ADJ. SCREW ASSY. - LEFT All 2
H1521 Front&Rear ADJ. SCREW ASSY. - RIGHT All 2
H1521-2 Front&Rear ADJ. SCREW ASSY. - RIGHT All 2
H403 Front&Rear ADJ. SCREW SPRING Manual Adjusting Brakes AR
H405 Front&Rear ADJ. SCREW SPRING Self Adjusting Brakes AR
H2090 Front&Rear CABLE GUIDE OR PIVOT All AR
H2090-2 Front&Rear CABLE GUIDE OR PIVOT All AR
H2102 Front&Rear CABLE OR LINK All AR
H2102-2 Front&Rear CABLE OR LINK All AR
H1132 Front&Rear HOLD DOWN BOTTOM CUP Manual Adjusting Brakes OR Self
Adjusting Brakes AR
H1132-2 Front&Rear HOLD DOWN BOTTOM CUP Manual Adjusting Brakes
OR Self Adjusting Brakes AR
H1111 Front&Rear HOLD DOWN PIN/ANCHOR Manual Adjusting Brakes OR Self
Adjusting Brakes AR
H1150 Front&Rear HOLD DOWN SPRING Manual Adjusting Brakes OR Self Adjusting
Brakes AR
H1150-2 Front&Rear HOLD DOWN SPRING Manual Adjusting Brakes OR Self
Adjusting Brakes AR
H1132 Front&Rear HOLD DOWN TOP CUP Manual Adjusting Brakes OR Self Adjusting
Brakes AR
H1132-2 Front&Rear HOLD DOWN TOP CUP Manual Adjusting Brakes OR Self
Adjusting Brakes AR
BH25160 Front&Rear HOSE - FRONT LEFT All 2
BH23057 Front HOSE - FRONT LEFT Frame Hose 2
BH25160 Front&Rear HOSE - FRONT RIGHT All 2
BH23057 Front HOSE - FRONT RIGHT Frame Hose 2
BH25159 Rear HOSE - REAR All 2
H131 Front&Rear RETURN SPRING Manual Adjusting Brakes OR Self Adjusting
Brakes 1
H131-2 Front&Rear RETURN SPRING Manual Adjusting Brakes OR Self Adjusting
Brakes 1
H2544 Front&Rear SELF ADJ. WHEEL KIT - LEFT All 1
H2544-2 Front&Rear SELF ADJ. WHEEL KIT - LEFT All 1
H2545 Front&Rear SELF ADJ. WHEEL KIT - RIGHT All 1
H2545-2 Front&Rear SELF ADJ. WHEEL KIT - RIGHT All 1
2017509 Left-Rear WHEEL CYLINDER - REAR LEFT All 2
WC17509 Left-Rear WHEEL CYLINDER - REAR LEFT All 2
2017510 Right-Rear WHEEL CYLINDER - REAR RIGHT All 2
WC17510 Right-Rear WHEEL CYLINDER - REAR RIGHT All 2
Front wheel cylinders (set)
1956-60 Lincoln - all (Old Parts Source Montville, New Jersey)
[attachment=0]wc23190-1.jpg[/attachment]
1 - WC 23190, 1 - WC 23191 new
3535 Front WHEEL CYLINDER REPAIR KIT - FRONT All 2
WK35 Front WHEEL CYLINDER REPAIR KIT - FRONT All 2
3513 Rear WHEEL CYLINDER REPAIR KIT - REAR All 2
WK13 Rear WHEEL CYLINDER REPAIR KIT - REAR All 2
Brake Hose Front LH 25160
Brake Hose Front RH 22700
Brake Hose Rear 26983
Brake Hose, Master Cyl. Frame 25161
Brake Shoe Axle Set Front 11-1/16x3-1/2 00124
Brake Shoe Axle Set Rear
Brake Wheel Cyl. Front LH 1-3/32 Bore 23190
Brake Wheel Cyl. Front RH 1-3/32 Bore 23191
Brake Wheel Cyl. Rear LH 15/16 Bore 17509
Brake Wheel Cyl. Rear RH 15/16 Bore 17510
Brake Wheel Cyl. Front Kit 1-3/32 Bore 19386
Brake Wheel Cyl. Rear Kit 15/16 Bore 03608
Switch Brake Stoplight 07715
New Front Wheel Cylinders brand new and precision machined to meet or exceed OEM quality.
Return to “MEL Related Shopping Guide”
