What valve springs are you using?
spectramal
Post by spectramal » Fri 26. Apr 2019, 11:47
I need to replace my original springs with something a little higher performance. Just wondering if you guys found a good spring to use. Most that I find in my comp book need to have the guide/spring seat milled down to fit. Is this a problem?
Treinarts
Re: What valve springs are you using?
Post by Treinarts » Thu 25. Jun 2020, 19:15
I used edelbrock rpm springs retainers and keepers for big block Chevy. Umbrella valve seals. Fit perfect. Ordered right out of Summit catalog. Tjr
Post by Chris430 » Tue 30. Jun 2020, 06:08
Treinarts wrote: ↑
Thank's for that information.
