Theo, I can't post to general specs but here are some (I saw you already had bore and stroke, but they're here again.)
GENERAL:
Bore: 4.3800"
Stroke: 3.8300"
Compression ratio: 10.25:1
Horsepower: 340 @ 4600 RPM
Torque: 485 @ 2800 RPM
TOLERANCES:
Piston to bore: .0015" to .0021"
Piston ring end gap:.010" compression rings .015" oil rings
Wrist pin diameter: .9750"
Rod bearings: 2.5992" to 2.6001" shaft diameter .0007" to .002" clearance
Main Bearings: 2.8994" to 2.9003" shaft diameter .0008" to .0024" clearance
Thrust #3 main: .004" to .008" end play
TORQUE SPECS (lb ft):
Spark plugs: 15-20
Heads: 135-145
Intake manifold: 20-25
Exhaust manifold: 15-21
Rocker Shaft: 45-50
Rods: 40-45
Mains: 95-105
Flywheel to crankshaft: 75-85
Harmonic damper: 75-90
Misc. 462 Specifications
66Lincoupe
Re: Misc. 462 Specifications
Yes, that section was kept locked as I wasn't sure how to handle it w/o a WIKI software. I opended it now.Please copy your post, then go to the appropriate section, create a response and paste the data into a new post of yours.
Check out my initial post, in this case in the 462 specs thread. I added a text where I announce my descision to merge the info into one single post while keeping the contributer's original post in line.
Thank you for your great contribution to the MEL Enginer Forum.
All right, I've moved this post so you won't have to repost.
Thanx again.
Thanx again.
66Lincoupe
Thanks Theo!
66Lincoupe
Theo, I must have skipped a line on the Crankshaft specifications when I was typing these... The rod specification is incorrect, however, clearance is correct...
I will fix my original post when I get home tonight.
Thank you for your notification. The specs are corrected according to your latest numbers.
