I need 430 parts
59mark4drop
I need 430 parts
I need the front power streering pump 3 3/8 hole Harmonic balancer . All brackets .oil adapter / fitting and lines Exhaust manifolds . throttle bracket to Kick Down for transmission please call 405 8245369
Re: I need 430 parts
I pulled the transmission and gathered up the 59 brakets per our conversations. When we spoke Wendsday you were coming. I called and texted you Saturday but no response. Hope all is well.59mark4drop wrote: ↑Wed 24. Jan 2018, 18:06I need the front power streering pump 3 3/8 hole Harmonic balancer . All brackets .oil adapter / fitting and lines Exhaust manifolds . throttle bracket to Kick Down for transmission please call 405 8245369
