What Not To Use On Stuck Pistons In The Cylinders
Post by Chris430 » Sun 27. Dec 2015, 16:10
I do not know what was used but it was toxic to the aluminium. If not already covered this would make a good sticky post. Maybe it will keep others from screwing up pistons. Engine did get water at one time. Pictured is the diesel I put in the cylinders.
Re: What Not To Use On Stuck Pistons In The Cylinders
Post by Chris430 » Sat 9. Jan 2016, 07:32
Someone mentioned Muriatic Acid. Muriatic Acid will corrode iron pipes. Knowing that I personally would not risk ruining the heads and valves.
