PBB-7003-F Questions
Senior Airman
Senior Airman
Post by Chris430 » Fri 27. Nov 2015, 13:52
Good afternoon,
I have an LX transmission from what seems to be a 59 Lincoln 430. How does this transmission compare to a C6? If used in place of an FE C-O-M will the gear selector read correctly or be a little off as a C6 would be? If this is a strongest pre-66 automatic transmission, I'll keep it around.
Senior Airman
Senior Airman
Re: PBB-7003-F Questions
Post by Chris430 » Thu 30. Mar 2017, 21:24
I check in every couple of days. Anyone feel free to post.
Post by 59lincolnrag » Tue 25. Apr 2017, 17:44
There is no comparison to a C 6. This is a different unit all together.
BTW ...
The PBB is the large case unit. and has two pumps front and rear, This allows the car to be push started.
2007 Merc Gran Marquis
1997 Lincoln Town Car
Senior Airman
Senior Airman
Post by Chris430 » Tue 25. Apr 2017, 21:07
BTW ...
I remember those in old GMs also.
Is there an aftermarket valve body for the LX that allows a first gear take off in drive and a manual shift?
Post by 59lincolnrag » Wed 26. Apr 2017, 03:14
Not that I know of .... But you can certainly make that modification if you want to ..
This is a twin range unit it can start in first or second .......
Senior Airman
Senior Airman
Post by Chris430 » Wed 26. Apr 2017, 20:02
Looks like the gear selector is the same throw as the COM. I didn't find any comments to my strength comparisson question vs a C6 but I didn't find anything negative about the Twin Range either. Doesn't look like a bad transmission. Thanks for your help.
Return to “MEL Transmission”
