What are the negatives to swapping a 62 2 bbl to a 63 4 bbl?
Have a 63 430 I just pulled from a salvage vehicle. I also have a 62 430 with the stock Carter 2 bbl. Since I now have a perfectly good 4 bbl intake & carb, is it possible to swap the intake & carb to convert my 62 to a 4 bbl?
Thanks in advance for the input.
62 430 carb swap
keithol
Re: 62 430 carb swap
It should bolt right in , just look for differences in throttle linkages and choke mechanisms.
