My name is Tracy and I am from Oklahoma and have been in Ca since 2000 and made it my permanent home after four years in the AF from 2001-2005. I am in the central Cali delta and own a 1961 50 foot Chris craft conni. She has two MEL 430s in it. I have reluctantly decided to rebuild these engines as the cost of re powering is almost twice the price as a rebuild. I love the way these old engines sing but hate there weak power output for there displacement, the last 350 chevy I built had 300hp and 400ftq. That is more than a marine 430 Lincon. I would much rather use a small block chevy and get much better fuel economy, or a set of diesels but as mentioned replacing the engine with anything other than original is much more costly.
Here is the project and it has a solid hull and was hulled out and all bottom work was done. I am currently working on making it look like new outside but am saving for the engines.
I am familiar through research with the Mel engine and hope I can rebuild these babies. Many use custom Pistons from wisco but that companies Pistons are crap. I would rather pay to have it sleeved and use used original Pistons. I am not a professional engine rebuilder but pretty competent. My last build was a weber 750cc two cylinder four stroke with 200hp. befire that was a old 350 chevy.
Both 430s run good but one has bad piston walk and sounds like a knocking rod at low rpm. Both have over 2000 hours.
