Which is the better block?
mercmike
Post by mercmike » Sun 28. Oct 2012, 20:08
I want to build the biggest cubic in MEL that I can. Should I use a 430 or a 462? Is one block stronger than the other? I'm not concerned with the trans bolt pattern. I will use an adapter if I have to.
Re: Which is the better block?
Post by Theo » Fri 2. Nov 2012, 17:55
Why not using a 462? It's the bigger motor to start from.
