Timing Gear?
LandCruiser
Music instruments you're playing: A little bit guitar, that i build by my own
Timing Gear?
Post by LandCruiser » Wed 6. Jun 2012, 07:06
Hi Folks,
how can i check if my Timing gear ist worn out, in my MEL462? can I hear it?
Thank in advance
Tom
austlinc
Re: Timing Gear?
Post by austlinc » Wed 6. Jun 2012, 22:31
Hi,
It is done visually, you will need to remove the water pump to see....
Cheers Angelo
LandCruiser
Re: Timing Gear?
Post by LandCruiser » Thu 7. Jun 2012, 00:16
Thank You, Angelo!
Re: Timing Gear?
Post by Theo » Fri 22. Jun 2012, 18:09
How many miles on the chain?
LandCruiser
Re: Timing Gear?
Post by LandCruiser » Sun 24. Jun 2012, 10:14
The ODO say´s 53000 and it could be ok, the "Gutachter"said.
