MOON VALVE COVER ALERT
Post by Chris Craft crazy » Thu 15. Mar 2012, 10:36
It seems that MOON products are now (re) producing the MEL 430 valve cover as a stock item. For those of you not familiar with this item, MOON products used to produce a cast aluminum polished valve cover for the 430, which is high enough for higher ratio or bulkier roller rockers. A custom run was done a year or so ago based on an assembled order list, but if you go to EBAY and search LINCOLN 430, you will find a couple of retail outlets offering the same valve cover... price is roughly 300 dollars per set.
As a buyer of the original custom run, I can tell you this is a very high quality valve cover, beautifully finished. I am currently using Harland Sharp roller rockers in billet aluminum and there is lots of clearance.
Re: MOON VALVE COVER ALERT
Post by Theo » Sat 17. Mar 2012, 04:48
Hmmm, smells like MEL revival?
Senior Airman
Senior Airman
Post by Chris430 » Wed 3. May 2017, 18:26
