valve covers
- buddy67lincoln
- Senior Airman
Re: valve covers
I should be able to use the timing cover without fuel pump if I use an electric fuel pump too, correct? Shouldn't be any different I would think.
Re: valve covers
Correct. Just make sure to use a fuel pressure regulator amd a fuel pressure gauge. Adjust the pressure regulator according to the carb's recommended psi.
Some fuel pumps come with an anti roll function.
