What was done to the heads? Larger valves? New valve spring assembly I assume. Slover did mine a few years ago.
Those are some good dyno numbers and a really good torqe curve. Your cam is milder than mine, but seems to do the job. TJR
Fresh MEL build
Re: Fresh MEL build: Results
Have you ran it in anything yet? It looks like it would be strong off idle. With the cfm your pulling it looks like you have it near 100% efficiencybrechlrl wrote:Here are the dyno results form the 517 motor. It was built with torque and pump gas in mind.. Lots of torque here
I may copy that exact build for my 59 build. EDG inake and Quadrajet or Thermoquad would be the only difference.
