affordable 430 pistons
nasty55ford
- Music instruments you're playing: 554/564 lift 292/320 duration voodoo cam in my 430
Re: affordable 430 pistons
yes if you go on to rockauto.com and put in your info this is what i like abought that sight then click on timing gear/chain it will show you several that they have that will fit and a cross reference comes up with part numbers also i think 351 clevland 400 m truck will also work its on there and it also cross references with a 56 pontiac as well and the best thing they actualy have pics that go with the part number
petemonster
Very cool Thank you.Do you have a part number for the pistons.I just heard back from Wally at Badger and he says they don't have a mold that he is aware of but he will check,and if I had anymore additional info that may help.
nasty55ford
i will talk to him today see whats up he has a 59 piston 10.1
petemonster
Did the 59 use the flat top?
No.petemonster wrote:Did the 59 use the flat top?
nasty55ford
i spoke with wally he said when you emailed him he was thinking abought 429/460 pistons and asked you for a part number he said he totally forgot abought the mel and he says yes he has his mold and he is ready to rock out some pistons unless someone is using chevy 6.8 rods then he needs deck hight ect call him or email thank you
nasty55ford
i will have to post some pics of the new badger run when he makes another set
I'm sorry. I was just answering his question about the flat piston heads, and attached the link talking about it. I've removed the link from my post.nasty55ford wrote:another wiesco advertisement. that is the whole reason i started this thread to veer off off that one.i will have to post some pics of the new badger run to get off that one .
nasty55ford
thats cool thanks trying to make the pics work but havent firgured it out i tell ya my pistons are real close to flat tops wedge is less than a quarter inch high i forgot to take pics of them before i put the heads on ill try to get some video of this thing when i get it all back together
nasty55ford
we will have to do a comp test with the badgers see if they stack up to the other guys
