I need your great help (again). My engine is finally running and my rebuild trans is also driving both forwards and rearward (clutches where glued together due to water in the trans).
Now my power steering (pump) is making a lot of noise. Wenn steering to the right there is quit a loud sound coming from the lower part of the engine. When I provide some pressure on the steering wheel to the right the sound is gone. If I loosen the steering wheel it slowly pulls to the left (not driving and with the engine at idle) and starts making the noise. It also keeps slowly keeps turning. Power steering is working without hesitation.
I took apart the pump and steering gear to give it a reseal and cleaning. Before that it was working perfect except for the leaks.
Hope to solve the problem as I still can’t drive the car now....
Thanks, Ferdy
