430 internal oil tubes
frostbites
Music instruments you're playing: guitar
Post by frostbites » Fri 28. Apr 2017, 15:30
Hi everyone,
New to the forum, a lot of info on here!! I have a 430 that I have stripped down and was wondering if anyone has replaced the oil lines / tubes that run behind the frost plugs? Mine are rotted off. Thanks. B
Re: 430 internal oil tubes
Post by Chris430 » Tue 2. May 2017, 15:20
If it is the lines that go to the vacuum pump mounted to the oil pump, then it is a vacuum line. I am not going to use the fittings off my 60. If your in the US you can have mine.
brechlrl
Post by brechlrl » Sun 7. May 2017, 06:59
If you are talking about what I think you are, those are not oil lines behind the core plugs they are support rods that help hold the casting mold together, They really have no function at this point. Most engines have them
