Fresh MEL build
brechlrl
Fresh MEL build
Post by brechlrl » Sun 8. Dec 2013, 09:40
I just broke in the cam on this engine It is a 515 inch ported heads 10.5 compression with a Slover adapter and a Performer RPM from a 460.
It should make about 525 horse and close to 600 lb of torque. It will be on the dyno in the next few weeks
Re: Fresh MEL build
Post by Shelby#18 » Sun 8. Dec 2013, 20:43
That looks pretty darn awesome!
Re: Fresh MEL build
Post by Theo » Mon 23. Dec 2013, 04:10
Ooooh, yes
brechlrl
Re: Fresh MEL build: Results
Post by brechlrl » Fri 24. Jan 2014, 15:50
Here are the dyno results form the 517 motor. It was built with torque and pump gas in mind.. Lots of torque here
vanscooter
Re: Fresh MEL build
Post by vanscooter » Fri 24. Jan 2014, 19:07
Great job !!!!!! Is the crank an offset grind for stroke ? What are you putting it in ?
brechlrl
Re: Fresh MEL build
Post by brechlrl » Sat 25. Jan 2014, 08:36
So far I do not have a car to put it in. I just like building motors lol
The crank is offset ground to a 4.21 stroke and uses a 2.2" BBC rod bearing
vanscooter
Re: Fresh MEL build
Post by vanscooter » Sat 25. Jan 2014, 13:10
Thanks. Saw you on the FEForum
Re: Fresh MEL build
Post by Theo » Fri 31. Jan 2014, 12:34
Treinarts
Re: Fresh MEL build
Post by Treinarts » Wed 12. Feb 2014, 09:11
Impressive. What cam are you running? Nice flat torque curve. TJR
brechlrl
Re: Fresh MEL build
Post by brechlrl » Sat 22. Feb 2014, 18:34
Cam was ground by Jones Cams in North Carolina on a blank that I found years ago. It is hydraulic and a 244/244@ .050 and .500 lift.
