Some wear on push rod and timing chain maybe...
t_of_sweden
Post by t_of_sweden » Thu 8. Nov 2012, 14:23
My push rods for the 1:st cylinder..
The left one wich is the intake looks as a moskeé and is probably worn out, or??
And the right one is the outlet, rest of them looked as the right one.
The 430 has been a bit lazy, i promise you that, because the intake hasn't opened for quite a while...
Any ideas somebody, how that has happened??
VIDEO0006.mp4
Some wear in all directions on the timing chain i think.
(3.83 MiB) Downloaded 1750 times
T.
Edsel Citation 4-d HT 1958
Re: Some wear on push rod and timing chain maybe...
Post by Theo » Sun 11. Nov 2012, 02:54
Hard to tell what the problem was. Metallury, wrong lifter pre load, wrong length of the push rod, rocker arm failure....etc.
Make sure to replace the push rod together with the rocker arm as well. Check for proper length and pre load.
Good luck
t_of_sweden
Post by t_of_sweden » Sun 11. Nov 2012, 12:02
I'm gonna swap both lines of push rods...
T.
Post by Theo » Sun 11. Nov 2012, 17:40
Looks like the push rod in question was starving from insufficient oil supply. See its' dark blueish coloration beneath the tip. This possible cause would explain the tipp's abrasion.
Make sure to disassemble the rocker arm shafts and flush clean everything. The shafts can accumulate a lot of grime that can block oil flow to the rocker arms.
t_of_sweden
Post by t_of_sweden » Mon 12. Nov 2012, 00:40
That sounds like a probable reason because the rocker arms on the 1:st cylinder and the valve springs were covered with a sticky mass, however i'm gonna replace as most parts as possible with new ones, mayby even the rocker shaft if it is worn out...
I have senn on pictures in this forum that the heads came in two different sizes on valves, is it anybody who had measured the different valves so I can find out wich size I got????
More pictures are on Facebook, just copy and paste my name down here and add me as a "Friend":
Tommy Myran Nyström
and explain u are from this forum an I accept it.
T.
Post by Theo » Mon 12. Nov 2012, 02:45
Check out this section. Lots of information.
viewforum.php?f=29
