58 Merc Park Lane Super Marauder -- Part IV Fuel Pump
scatpack
Post by scatpack » Tue 9. Aug 2011, 15:59
Attached below are images of the fuel pump before and after restoration. Again more images to use as reference.
This is the original condition of the fuel pump. The aluminum tri-port housing is an excellent shape and just requires a thorough cleaning. Note the blue paint on the fuel filter canister. For some reason the previous owner painted this blue?
Fuel filter & canister removed.
Fuel pump restored using an original Ford Re-manufactured fuel pump. Note the factory ink stampings on the pump housing. The aluminum fuel pump housing was cleaned and mildly polished. I wanted to keep an original bright aluminum finish without the over-polished chrome look.
Inlet side of the fuel pump.
